Detail view callout.
I posted this question in the ASME Forum which was probably not the right place for it, so I will re-post it here, sorry for my newbe ignorance to the layout and sections of these Forums.
In the ASME Y14 Standards I have not been able to find any information stating the proper callout for DETAIL VIEWS. Such as "SEE DETAIL A". When defining a DETAIL VIEW in Pro-E by default the view callout will include the "SEE" preceding the "DETAIL".
I have looked through Y14.3, Y14.4, Y14.24 and Y14.100 and have not found anything specific, I have found an illustration in the Y14.24 showing a callout of "SEE VIEW B" but nothing stating a Standard of such. Anyone know where I can find something with this info specific to the correct callout?
Martin
Martin
RE: Detail view callout.
The Figure 23 is how it will show in Pro-E if the "Options" are set to "asme_94_circle" for the "detail_view_boundary_type" setting. If the setting is set to "circle" with the "view_note" setting set to "std_ansi" the "SEE DETAIL ?" will be displayed.
Thanks again,
Martin
I believe either way is acceptable, if that is your company standard.
