creating/assigning material in ProE wildfire 3.0
Sorry for this question which is certainly very basic for most of you, but I am novice at ProE and I have to train by myself...
So here is my question, what should I do to create and assign materials to parts in proE ?
The second question would be where could I find the mass and moment of inertia of each parts but I think it is in the menu Analysis->Model->Mass properties and "display info"..
Step by step description would be appreciated considering I am a novice..
Thomas
Thomas
RE: creating/assigning material in ProE wildfire 3.0
1. Gather data on the materials you will be using - the absolute minimum is:
Density ; Poissons ratio ; Youngs Modulus ; Thermal Conductivity
2. got to Edit -> Setup -> Material
3. File -> New
4. Name the material & put the data into the file (you can also add a colour to the material if you want)
5. Save to model
6. Decide where you want to store all the material files (eg {network drive}\Wildfire\materials)
7. highlight the created material and use File -> save a copy to save into the directory chosen
8. repeat steps 2 to 7 to create all the materials
9. right-click on the material you want the part to be & Assign the material to the part
10. in the config.pro file (Tools -> Options) add:
pro_material_dir {network drive}\Wildfire\materials
(11. to add the created materials to another part, all you need to do is repeat step 2 and right-click on the material in the right-hand pane & Assign the material)
The mass & moment of inertia are where you think they are.
You need to assign the material mass before Pro E will give reliable inertia data.
whilst in the part go to...
Edit>
Setup>
Material> To set up material for part.
Mass Props> To assign a mass to the part.
Units> To give the correct metric/imperial output.
Pro E gives mass in tonnes per cubic mm.
When you assign a material to a component, the density will change but the appearance will not.
The appearance can be changed by clicking on View> then Colour and Appearance>. Then by selecting and modifying the colours.
Adrian
