What is the Proper material callout
I need to know the proper BOM callout for .500 dia x .035W 304 s/s tubing. It is going to be used in a potable water system on an airplane. on the BOM in the STK SIZE column do i put 304 S/S ? and what about the specification column. do i put AMS ?????? or ASTM ???? where do i find these specifications. i need to know the proper way to call out this material. any help would be appreciated. thanks
RE: What is the Proper material callout
The specification column would call out the diameter, wall thickness and material callouts for the tubing itself (per whatever standards are required).
Hope this helps a bit.
can you refer to a previous job and look how they filled the material list then?
desertfox
the length is called out in the qty squares. I wish there was a go-by dwg but this is a one-off aircraft interior. what i really need to know is what is the ASTM or ASE-AMS number for .500 dia x .035W seamless 304 S/S tubing. that would do it. And i cant find it anywhere. I did find ASTM A 269 but it is for .028w un-bendable SS tubing. Well thanks For the help
http://www.frysteel.com/
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated 10-07-07)
"TUBING .500 dia X .035W X (Length) ASTM A312-304 SMLS. If you don't specify "seamless", you will get welded.
ASTM A312 is for CRES pipe.
sorry I am not the person u think I am
desertfox
