ACI 318-08 and work stress alternate design methods
Under the new 318-08   is the old alternate design method using working stress design permitted,   For simple quick design and checks, we would like to still utilize work stress design..
slip
RE: ACI 318-08 and work stress alternate design methods
The 318-99 had Appendix A, which included provisions for Allowable Stress Design.  This was removed in the subsequent 318-02, 318-05 and the current 318-08.
I don't have a copy of the 318-08, but both the 02 and 05 codes have, in the commentary of chapter 1, the following:
"In the 1999 code and earlier editions, Appendix A contained provisions for an alternative method of design for nonprestressed reinforced concrete members using service loads (without load factors) and permissible service load stresses.  The Alternative Design Method was intended to give results that were slightly more conservative than designs by the Strength Design Method of the code.  The Alternative Design Method of the 1999 code may be used in place of applicable sections of the code."
Here's what 318-08 states in Chapter1
"Appendix A of Codes prior to 2002 contained provisions for
an alternate method of design for nonprestressed reinforced
and permissible service load stresses. The Alternate Design
the Code. The Alternate Design Method of the 1999 Code
may be used in place of applicable sections of this Code"
Looks the same
