elevated pipe support
Hey there - I need to provide a detail for supporting 4 steel pipes laying side by side. The support will be 7' high and outside. I am not familiar with pipe support products beyond stanchion saddle-type supports.  The client has provided a sketch of what they envision - a single steel pipe column supporing a platform at the top. What is typically used for the platform supporting the pipes?
(this was submitted on the mechanical site as well so you may see it twice)
RE: elevated pipe support
These are typically called "pipe racks".  And I believe there are some codes for them.  Search these forms - I have seen it discussed a few times.
Any wide flange shape that meets the deflection and stress requirements, (50 psf minimum for supported area, span times the width of support beam).
