Propane Flames
Propane Flames
Propane Flames
Is it possible to manipulate a propane flame from a disposable tank to achieve oxidizing, neutral, and reducing flames?
RE: Propane Flames
What is you particular application?
There are types of burners and torches that use Propane and Air or Oxygen for that will give you any type flame you need.
RE: Propane Flames
I want do some brazing.  Most likely with a silver filler metal.  I have one of those single disposable propane tanks.  Is that sufficient?  Would a MAPP disposable tank be a better idea?  Again, if the fuel supplied from a single tank(no oxygen tank) is it possible to manipulate the flame?  In other words, would twisting the single knob change the amount of air mixed with the propane or am I just going to have to break down and obtain a dual tank kit?
RE: Propane Flames
You can do the things you mention with most torches but if you need higher heat output you have to go to an oxy/air/fuel torch.
Look down the page at propane torches. These are a just a few on many propane/mapp torches available.
You might want go to a refrigeration/air conditioning supply store and look at some of what's available.
There are sites on the net that supply just jewelers torches.
http://store.cyberweld.com/turbotorch.html
RE: Propane Flames
You can
Use some fire bricks and build a little box furnace - use lots of Black flux
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
