NX5 dimensioning
NX5 dimensioning
NX5 dimensioning
Is there a way to dimension to an intersection point in NX5? ... if there is, I sure can't find it.
RE: NX5 dimensioning
Can you add a theoretically intersection point and dimension to that?
Not sure if it's the same as NX3.0, but under 'Insert - Symbol - Utility Symbol - Intersection', just pick the two edges you need and it creates it.
Justin Ackley
Designer
