NX3 Multiple Plots
NX3 Multiple Plots
NX3 Multiple Plots
Is there a way to send a batch of drawings to the plotter (in this case, the printer and creating HPGL files)?
We have some larger assemblies, some times 15-20 parts, and want to see if I can save some time.
Justin Ackley
Designer
RE: NX3 Multiple Plots
Anyone have an idea?
Justin Ackley
Designer
Plotting can be done from an NX Open application.  In fact I suspect that there might some programs like that available from the PLM World download site.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Another thing that we have had some recent luck with is plotting multiple sheets out of NX-5, which you can probably do for NX-3 also, and then via postscript on the fly to a PDF printer. We have used 3rd party software to create PDF files of multiple drawings which can then be printed either full scale or on regular A3 and A4 paper. I like to put all the drawings for a product or assembly into a single file and control the releasing and product configuration very simply and directly.
The one we're using is PDF creator which you can find on the internet at pretty low cost I believe.
Best of Luck
Hudson
I was poking through plm world and didn't have any luck with finding anything.
Justin Ackley
Designer
