Steel Pipe Schedule go beyond 48"
Anybody know if there is a pipe schedule for pipes larger than 48"?
Is there a size standard for steel and pvc pipes larger than 48"?
RE: Steel Pipe Schedule go beyond 48"
yahoo123
API 5L has pipe schedules up to 80".
Greg Lamberson, BS, MBA
Consultant - Upstream Energy
Website: www.oil-gas-consulting.com
Thanks Greg,
But I'm wondering if there is a standard for potable water transmission lines.
You can get ductile iron pipe to 96" dia. under ANSI/AWWA C105/A21.5 and ANSI/AWWA C600.
You can get FRP pipe up to 158" dia.
AWWA C950, ATSM D 3517 and ASTM D3262.
http://64.233.167.104/search?q=cache:tXyMrI95hm4J:www.futurepipe.com/downloads/usa/VLDP_brochure.pdf+large+potable+water+pipes+frp&hl=en&ct=clnk&cd=4&gl=us
You can get steel pipe up to 144" dia.
AWWA Manual M11 for steel water pipes
You can also use concrete.
Thanks!
There are many AWWA C2xx series standards applicable to many aspects of steel water pipes, from manufacturing to various schemes of coating and lining etc., in sizes including at least 6"  to 144 inch (that are incidentally referred to in the AWWA M11  manual Mr. bimr mentions).  As far as pvc water pipe greater than 48" size, I am not aware of any standards applicable to pvc pressure pipes that large (but like you will await any more learned response).  It appears also e.g. from the document I've noticed at the site http://www.rpwco.ca/pdf/peel-pvc-app-1-3.pdf that maybe even e.g. in Canada (where I know there is heavy promotion of even large diameter plastic pipes, and no domestic production of e.g. ductile iron pipes) it appears that fewer large diameter lines may have gone that way than steel/concrete or ductile iron.
For 48" steel water line for potable water, the pipe would quite likely be custom made for the application.  Wall thickness and ID/OD can be adjusted as desired.  It is not uncommon, for example, to make the mortar lining ID the nominal ID, which gives you an odd OD.
