Wrap spring clutch design basics
Can anyone direct me toward, or eamil, resources that deal with the design of wrap spring clutches? I designed one about 15 years ago and have misplaced all my reference materials. Thanks.
RE: Wrap spring clutch design basics
Don
Kansas City
Not a full design treatise but it might be a start.
http://b
An overrunning clutch is, as you say, just like a sprag clutch, or just a one-way bearing.
A single-revolution clutch uses the wrapped-spring concept, but also includes a single-revolution tripping mechanism.
There is a pawl that engages a single stop tooth on the output that is also connected to the release tang of the spring. As long as the pawl bears against the tooth, the spring's engagement with the driving shaft is released and the input motor spins freely with no effect on the output. A solenoid can be pulsed that lifts the pawl out of tooth engagement. Since there is no longer any pressure on the release tang, the spring grips and engages the output to the input. The solenoid is only pulsed, so it is released as soon as the pawl is past the tooth. So the tooth rotates around one revolution and smacks into the pawl again, releasing the input to idle again. The tooth is part of the output shaft, so even though there is some slippage during acceleration, you get exactly one revolution every time with no cumulative error.
Is this the device you are talking about?
Don
Kansas City
Sorry about the confusion. The link I attached was not intended to show how I will use the clutch but just an example of a wrap spring application. The clutch will be used in an overrunning application. With that said, can you direct me to design resources for wrap spring clutches?
I wholly agree with your post as I hadn't refreshed my screen to catch the OP's second post prior to posting the link for the single wrap spring devices.
I don't normally equate the aforementioned devices to a wrap spring device.
There is an excellent design reference on spring wrap clutches published 30 years ago by the engineering staff at Sikorsky. You can download it free at the DOD STINET website:
http://stinet.dtic.mil/
It's titled "Helicopter Freewheel Unit Design Guide".
Thanks. That report was exactly what I was serching for. I'll need to have a deeper look in that site as needed. Israelkk, looks like our plot was fouled!
