spline converter
spline converter
Hii All..
I need a macro that converts a lot of curves to arc and line in dertermined tolerance.
Rules:
1. created arc and lines lenght should be min. 0.25mm
2. arc and lines should be tangent eachh other.
3. some of arc and line can be grouped
You could see sample data that will be convert to arc and line at the attachement
Rules:
RE: spline converter
if you want help doing this you could start by trying to record the macro with tools>macro>start recording, for starters, and try to make some headway like this...
We can help you out if you have specific questions relating to how to make things work but I don't think you'll get anyone to do it for you...
regards
luis
thanks for your help.
