How to select part model sketch entities in assembly model
In a part model as a last step I created a plane and a sketch with a circle to be used to orientate the part in an assembly model.
In my assembly model, How do I select the sketch circle, to mate to the origin of the assembly? I show the sketch ok, but I can't select the circle or it's center point.
I tried searching for a solution but couldn't find anything
Tom
Tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Pro & PDMWorks 2007 SP3.0
RE: How to select part model sketch entities in assembly model
If you can't see them, select the part's sketch in the feature tree, RMB and show.
If it's still not visible, check under "View" to make sure sketches are selected for visibility.
Eric
Dan
www.eltronresearch.com
I can see the sketch entities when I show the sketch, but I cannot select them. I played around with the selection options in the options menu but had no luck with that either. I know I had this working in 2007 but not yet in 2008
EEnd, excuse my ignorance, but how do I create a coordinate system in the part? and then how do I mate that in my assembly?
Tom Malinski
Eric
Do you have Selection Filters selected?
KITRACER,
If the part is 'behind' the sketch, you are probably selecting features of the part rather than the sketch elements.
Can either or both of you post some images, files or (preferably) video of what you are seeing. As TheTick said, "You should be able to just pick them."
Tom
Tom Malinski
I usually always convert edges, etc of underlying sketch geometry.
I had this happen to me last week on some stuff I was working on. I do this all the time and could not get it to work with this particular set of files.
A system restart tends to help that, even better if I let it sit overnight. I think SW just gets stubborn at times.
Cheers,
Anna Wood
SW2008 SP3.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
Then I was able to go into the other part I was working on in the assembly and pick up the point to relate my new sketch geometry. A pretty easy work around.
Cheers,
Anna Wood
