Importing csv or txt files to create complex curves
Hi all, I was wondering if anyone had any experience with importing csv/txt files into Solidworks 2008? Is it possible? I have some very complex curves which I want to turn into 3D models.
Thanks in advance.
Thanks in advance.
RE: Importing csv or txt files to create complex curves
Thanks again!
Are you saying SW will not accept the file?
Which format are you trying to import? Only .txt or .sldcrv are allowable.
a) ALL numbers must be to the same number of decimal places (or at least you cannot have some numbers with and some without a decimal point).
b) SW won't accept a 0,0,0 point.
Got my curves imported now - thanks for the advice :)
How do i create such curves in solidworks.
what is funcPlot and SurfPlot, never cme across this.
can you kindly guide me through this.
well in importing the file. i dont think thee is much problem with the decimal points.
well but i dont have problem in importing the text file that i created from excel. it doesnt take it...
can you tell how do i export my points from the excel.
is there any we can make use of design table in order to create functional curve
thanking you
regards
kartik
