Offset feature Dim Display
Good morning all,
I'm fairly new to SW (2007 SP4)
I have a back ground of Proe, and like to produce models with dimensions that i can stick straight into the drawing.
My problem is when i produce a shaft with different dias, i create it with offset cuts, but these offset dimensions dont display. I want to add these dims to a design table, but cant find them anywhere. They dont even show on the drawing when i show "Model Items"
Can anyone show me the way to display these?
Thanks in advance.
Mark
Thanks in advance.
Mark
RE: Offset feature Dim Display
There are a few features in SW that don't have any displayed dimension you can access. If I understand right, you have found one of them - extruding offset from the sketch plane. A couple others are the "move face" command and any of the "move/copy" body commands.
Have you considered modeling your shafts (and indeed any round/lathe parts) with revolve features rather than extrudes?
-handleman, CSWP (The new, easy test)
Bit of a shame, has anyone found these dims?
What do you mean? It sounds like you might create a 2" diameter shaft, and if you want a 1 1/2" diameter shaft, you offset the circle by 1/4" and extrude cut, is that correct?
If that is the case, why not simply make the dims configurations specific and change the diameter of the 2" to 1 1/2" and you do not need to ad the cut feature.
Flores
The problem being that the value of offset doesnt show, only when you edit the feature, so it cannot be used in a design table.
I have used a revolved cut now, i would prefer not too as there is alot less to go wrong with sketching one circle and extruding a cut than sketching multipul lines to revolve.
A matter of preference i suppose?!?
CODE
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
|______ __|
|__________|
