How to calculate frequency at given time using sweep rate?
We recently subjected one of our devices to a sinusoidal vibration test (per MIL STD 810F, method 514C-18) at a local test house that used a sweep-rate of 0.2215 octaves per minute. The 810F test is performed in 3 axes, consisting of six (6), 30 minute sweeps per axis, ranging from 5 Hz to 500 Hz (acceleration .2 to 5.0 G's).
Two incidents occured at elapsed times of 00:37:53 and 01:37:50 {hr:min:sec}. I need to determine the respective frequencies that correspond with these times. I do know that a frequency doubles after each succesive octave (7 in this case*) but I am not sure how to use this towards solving for the desired frequencies.
I have spent much of the day searching the web and am more frustrated after encountering many rigorous, seemingly endless mathematical equations on the subject (Fourier FFT, etc)but am no closer to a solution.
I appreciate your help.
* 810F test Octaves @ frequencies (Hz):
5-10, 10-20, 20-40, 40-80, 80-160, 160-320, 320-640.
RE: How to calculate frequency at given time using sweep rate?
If so, then the frequency should be
5 Hz * 2^(7.8833) = 1180.5647 Hz
TTFN
[ANSWER TO YOUR QUESTION AND MY COMMENTS ARE BRACKETED]
Your information seems to still be incomplete.
Is each sweep immediately after the previous? [YES]
i.e., does 00:37:53 represent 7:53 into the second sweep?
[YES]
[THIS IS INCORRECT SINCE THE TEST FREQUENCY RANGES BETWEEN 5 TO 500 Hz. WHERE DID THE 7.8833 COME FROM & WHAT EQUATION ARE YOU USING? I DONT SEE WHERE THE GIVEN SWEEP RATE OF .2215 OCTAVES PER MIN IS USED IN THIS SOLUTION].
Please see attachment 810F profile for clarification.
JCM
IRstuff's equation should be
freq = (5 Hz) * 2^(t/.2215) for 0<t<t1
and freq = 500*2^(-t/.2215) for t1<t<2t1
and repeating thereafter
t1 occurs when f = 500 Hz, or
2^(t1/.2215) = 100
(t1/.2215)ln(2) = ln(100)
t1 = 1.4716 minutes or 01:28.296
At 7:53 into run #2, you are in period #5, so use eqtn 1 with t = .5253 minutes, which gives freq = 25.9 Hz
Or at least, that's what I get...
7.8833 min is 7:53 in decimal minutes. I forgot to multiply by .2215 oct/min
5Hz*2^(7.8833min*.2215oct/min) = 16.77 Hz
The period is 30 minutes. The .221462 oct/min puts the frequency at 500 Hz at the 30 minute elapsed time: 5Hz*2^(30min*.2215oct/min) = 500.3966 Hz
There is only one equation:
5Hz*2^(modulo(time,30min)*.2215oct/min)
This is cautionary tale of why you should ALWAYS keep units in the calculations, since it would immediately be obvious that the construct:
t1*min / .2215oct/min should have been t1*min * .2215oct/min
TTFN
PLEASE ANSWER MY QUESTIONS BELOW [BRACKETED]:
[I ASSUME THAT THIS IS "eqtn 1" you are referring to below?
CAN YOU TYPE OUT THIS EQUATION OR DIRECT ME TO A WEB SOURCE WHERE I CAN SEE THE DERIVATION OF THIS EQUATION?
ALSO, WHY IS 5 Hz PART OF EQUATION 1 SINCE FREQUENCY OF 5 Hz OCCURS ONLY AT THE BEGINNING OF SWEEPS #1, 3, & 5 AND AT THE END OF SWEEPS #2 , 4 , & 6? I AM TRYING TO SOLVE FOR A FREQUENCY THAT OCCURED AFTER 5 Hz (i.e., at ELAPSED TIMES OF 37.8 MINUTES {OR 7.8 MINUTES} INTO SWEEP #2 AND 96.8 MIN {OR 6.8 MINUTES} INTO SWEEP #4]
[LIKEWISE, WHY IS 500 Hz PART OF THIS EQUATION AND WHY IS A MINUS t (-t) USED IN THIS EQUATION?]
t1 occurs when f = 500 Hz, [WHY DOES t1 OCCUR AT 500 HZ AND NOT AT f TO BE DETERMINED AT 7.8 MINUTES?]
or 2^(t1/.2215) = 100 [WHAT IS AND HOW DID YOU GET 100?]
[IT'S UNCLEAR WHAT YOU MEAN BY "period #5"? DO YOU MEAN A PERIOD OF TIME OR AN OCTAVE? OCTAVE #5, e.g., STARTS AT 80 AND ENDS AT 160 Hz.],
[25.9 Hz SOUNDS RIGHT BUT NOT SURE HOW YOU ARRIVED THERE. HOW DID YOU FIND t=.5235?]
P.S.SORRY TO ALL FOR THE LONG STRING.
JCM
If you had a linear sweep of frequency vs time, the units would be hertz per minutes.
But you have not specified a linear sweep, but a sweep in the form of octaves per minute. A little thought should convince you that requires some form of exponential. This is the exponential equation which fits your data.
If that is not obvious, at least consider that it amounts to a straight line on a curve of ln(f) vs time. (agreed?)
Find the equation of the line:
ln(f) = m * t + b
that satisfies:
ln(5) = m *(0) + b
and
ln (2*5) = m * 0.2215 + b
Solution of two unknowns m and b from two equations gives:
b = ln(5)
m = [ln(10) - ln(5)]/0.2215
So the equation is:
ln(f) = ln(5) + {[ln(10) - ln(5)]/0.2215} * t
ln(f) = ln(5) + {[ln(10/5)]/0.2215} * t
ln(f) = ln(5) + {[ln(2)]/0.2215} * t
ln(f) - ln(5) = {[ln(2)]/0.2215} * t
ln(f/5) = {[ln(2)]/0.2215} * t
ln(f/5) = [ln(2)] * (t/0.2215)
take exp ( ) of both sides
f / 5 = 2 ^(t/0.2215)
f = 5 * {2 ^(t/0.2215)}
where f in hz, t in minutes
"This is the exponential equation which fits your data."
should have been:
"This is the exponential equation which fits your specification (0.2215 octaves per minutes, starting at f=5 when t = 0)."
The derivation simply comes from
f(30minutes) = 500 Hz = 5 Hz * 2^(alpha * 30 minutes)
ln(100)/ln(2) = alpha * 30minutes
alpha = 0.2215 octaves /min.
Therefore, the correct equation is
freq = 5 Hz * 2^(time * 0.2215/minute)
TTFN
The derivation is the same.
Change
to
ln (2*5) = m * 1/0.2215 + b
And invert 0.2215 everywhere it appears after that.
Either derivation is fine imo.
Since 7:53 is less than twice that value, the frequency must be less than 20 Hz for the "event."
TTFN
Thanks to IRstuff and electricpete for your collective input.
JCM
Using the previously derived equation to calculate frequency f = 5 Hz * 2^(t * .2215/min) at t = 6.783 minutes yields
f= 5* 2^(6.783 * .2215)= 14.36 Hz?? This is incorrect since I know at 14 Hz, A = 2 g's per the 810F sweep file attached, and the frequency must occur at A = 5 g's.
Since we are starting the 4th sweep at 500 Hz and heading back towards 5 Hz, I substituted t = 30 minutes - 6.783 = 23.217 minutes which yields a more reasonable frequency of f = 5* 2^(23.217*.2215)= 176.6 Hz when compared to figure 514C. However, following this approach in conjunction with the derived equation for f, I question why t = 6.783 is not substituted into the equation accordingly and likewise
500 Hz for 5 Hz...that is until realizing that calculated f would exceed 500 Hz???
JCM
f = 50Hz * 2(-t * .2215 oct/min) = 176.48 Hz.
As a check, t = 0 min results in the starting frequency of 500 Hz, and t = 30 min results in 4.996 Hz.
TTFN
http://www.vibrationdata.com/tutorials2/sweep.pdf
Tom Irvine
