Design problem
Design problem
Material engineering question. What material to use as a horizontal torque situation, “shaft for auger”? (Example: the shaft material of a 20' soil scratcher) Would you use structural pipe or structural tubing?
RE: Design problem
Regardless, I would use a material that is sufficiently strong for the application, and that meets whatever other unidentified requirements you may have.
RE: Design problem
I was asking about what kind of material to be use for
sufficiently strong for the application, is tubing or is it pipe and what kind ?
RE: Design problem
For a standard commercial grade pipe in carbon steel A53 gr. A is typically available where I am located.
EJL
RE: Design problem
I was trying to see what works better for a auger shaft, pipe or tubing and there strenght properties.
RE: Design problem
RE: Design problem
http
Ted
RE: Design problem
Mike Halloran
Pembroke Pines, FL, USA
RE: Design problem
From my experience as a fabricator, I found pipe to often have a straight seam which can fail; whereas tubing is usually made better, and of better stuff, and to closer tolerances. It just seems to me that tubing is better than pipe.
RE: Design problem
And for torque applications a round tube is more efficient than square. Not that you can't use square - just that it will need to be bigger than the round for the same torque load.
ISZ
