Eigenvalue Buckling
Eigenvalue Buckling
Eigenvalue Buckling
Can the eigenvalue buckling analysis determine whether the load applied will cause the model to buckle?
RE: Eigenvalue Buckling
Well, yes.  If the load applied is equal to the buckling mode, then you'd get an eigenvalue of ~1.
Martin Stokes CEng MIMechE
*EDIT* I meant buckling LOAD not MODE ....
So eigenvalues less than 1 would suggest buckling?
yes, the alternative is to put a unit load as the applied load and your first eigenvalue is now your buckling load.
Agree with MrMyers - that's exactly how I would normally do an eigenvalue buckling analysis.
