Add Sheet # to BOM table
Is there a way to add a parameter to my models so that they can determine what sheet# they are on when detailed.
Then add that parameter to my main BOM table so it displays what sheet# to go to to find that part.
Thanks in advance.
Jason
Thanks in advance.
Jason
RE: Add Sheet # to BOM table
I think the best thing to do is to generate a BOM table for each sheet of your drawing. This way you can specify what is on each sheet. I think this has to be done thru a table filter and/or picking items which are not on your sheet because when you place the BOM table it will just read the entire assy.
Hope this is of some assistance.
Fighter Pilot
Manufacturing Engineer
Peter Stockhausen
Pollak Switching Products
