TCP/IP/UDP Toolbox
TCP/IP/UDP Toolbox
I have a system that consists of a PLC that it is gonna send MATLAB some string messages and I have my MATLAB Application that is responsible to be the interface of a machine.
Using this toolbox I can already establish a connection between MATLAB and my PLC, but I cannot read the messages sent from the PLC to my MATLAB Application.
I've established the connection with the function:
sockcon=pnet('tcpsocket',8000);
pnet(sockcon,'tcplisten');
because in this case my PLC is the client and MATLAB the server and I'm using the port 8000.
My question is: what do I have to do to read the string sent from my PLC to MATLAB. I've already tried the functions:
data=pnet(con,'readline',1024);
data=pnet(sockcon,'read' ,['200'], ['char'], ['network'], ['view'],'noblock');
pnet_remote(con,'serverat');
but non of these three worked out.
Does anybody can help me?
Thanks a lot!
Thanks a lot!
RE: TCP/IP/UDP Toolbox
i have a problem like you. I want to cominicate with matla/simulink and a robot kuka via tcpip.i have some question about your solution...where do you find the pnet command? In the robot there is a visual basic program who send a string and receive a string...do you think it is possible to read and send data with matlab to the robot?
I am using the tcp_udp_ip toolbox with matlab 2007b. I can't seem to get data I know is being sent to read into matlab.
I have a program that is sending udp data on a certain port ( I know this because it comes with a command line reader that can read it) but when I setup the pnet command, I get a whole lot of nothing.
BRFE, what was your solution? Anyone else?
B
