Fabricated Pipeline Wye Piece
Has anybody modelled a 'Fabricated Pipeline Wye Piece'?
I am attempting to model one, but am having trouble in getting the cuts of the two pipes correct...
This refers back to an earlier question I posted with regards a 'Dihedral Chamfer'.
RE: Fabricated Pipeline Wye Piece
How are you modeling the two pipe branches?  If I understand your question, you want the cut to follow the non-horizontal pipe section.  Is that a correct interpretation?  To do this just start a sketch on the end of the non-horizontal pipe, draw a circle that is the dimension of the cut, and extrude the cut Up to Next.  Hopefully that's what you're asking...
Dan
www.eltronresearch.com
it is the chamfering which is causing the issue, i.e for weld prep as we have to get this wye tested and approved which includes a welding procedure...
Can you build the part by starting with a solid, shelling the solid, and then splitting the separate bodies off to create your individual pieces?  This way you wouldn't have to worry about cutting individual pieces perfectly to allow them to match up.
Start with two "raw pipe" components.  Position them in an assembly.  For each pipe, create 3D sketches in-context to represent the other pipe's centerline and OD.  This will give you the basis for creating the cuts you need.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
apparently this is 'TKY Joint'!
anyone know anything about TKY Joints?
What about using multi bodies and subtracting out one of the tubes to create the hole?
mncad
