Multiplex Comm1 in PC
Hi
For my application I need to read/Write Data betwen 2 diferents devices at diferents times and I was wondering if Can I use a mechanical cube relay to switch my RS232 Comm1 betwen this two devices?
Thanks for your help.
RE: Multiplex Comm1 in PC
This is an old Computer that has a Software application in Borland Delphi V3 by running in an OS Win NT 3.X
Actually Comm1 and Comm2 are busy and now my customer is requesting me to implement a RS232 Temperature Sensor
(http://www.sensorsoft.com/st6105c.html) by monitor the tempreature each 60Sec.
My problem is:
I dont have any PCI in spare in order to add a Serial Card
There are 2 USB but doesn't Work!
At this moment I was thinking in interconnect one of the Comms to an mechanical Relay and make switch between the Current device connected an the new RS232 Temperaure Sensor...
PLEASE if you have a better and clean idea let me know
I will appreciate your help!
Thanks in advance
It will also make your life easier as much of the work can be done at base rather than unknowns on site - potentially leading to savings for the customer as on site work and travelling is costly.
You can use USB to Serial adapters rather than having to use internal cards, this makes it a standard PC should anything fail in future. Easysync make industrial USB/serial convertors.
