Custom Properties help
Hi, I've been pulling out my hair all day trying to figure out how to do this. I want to bring my custom properties from a part file over to the custom properties to the drawing file. What's the best way to do this without having to manually? thanks!
RE: Custom Properties help
Try a search in this forum for "custom properties".
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated 10-07-07)
On the sheet properties window in the lower left there is an option "Use custom property values from model shown in" with a drop down list.
Would that work for you?
-Joe
SolidWorks 2008 x64 SP 3.0 on Windows XP x64
Dell Percision 490
Intel Xeon 5160 @ 3.00Hz (Duel Core)
8 GB RAM  -  Nvidia Quadro FX1700 (6.14.11.6262)
I'm sorry, that is not what you were looking for, but I know you can do it because I'm looking at a drawing that is doing it right now.
I just changed all our starter template 2 weeks ago so they would take the properties from the drawings and not the models. And now I'm pulling my hair out trying to find it, it was so easy the first time.
I'll keep looking because now I'm obsesed.
-Joe
Dell Percision 490
I found it....
It goes with my first post sort of.
When you are inserting the text and click the "link to property" icon you can select if you want it to link "to current document" or "Model in view specified in sheet properties" - default will work fine if there is only one model the drawing is made from.
Hope that helps....now I can go home.
-Joe
Dell Percision 490
tristram,
The OP wants the Custom Properties (i.e. File > Properties ... not the drawing annotations) of the part drawing to be linked to those of the part.
cheers
My Mistake CorBlimeyLimey, sorry cynlix for any confusion.
-Joe
Dell Percision 490
I assumed he/she wanted the custom properties to populate something in the drawing, which would make copying them unnecessary, you could just use them from the model.
-Joe
Dell Percision 490
Thanks everyone for the help. fcsuper, that is EXACTLY what I needed. Thanks!
