API 610
API 610
hello,
API 610 10th edition, requires gussets for auxiliary piping.
Welding qualification and performance qualification are required, dimensions for gussets are defined, but nothing for the type of welds,design of welds, the rules for crossing, or proximity of welds.
Do you think that we have to applied ASME VIII rules,and if yes what ยง we have to applied.
Thank you for your help.
RE: API 610
This asme standard up-graded to edition 11th?
Now an ISO standard.
To my knowledge auxiliary piping shall be designed, fabricated and tested for at least ASME B31.3
I would keep distance between adjacent welds > 50 mm
RE: API 610
Is it allowed to use a vertical storage tank built under API 650 (or BS 2654) as a digister with an overpressure
of .35 PSi at 120 F.
Kind regards
