ACAD 2002 multiple sessions.....
Is this possible. I used ACADR14 for the longest time but it was great for dual monitor setup. Can 2002 and later, do the same. I know you can have multiple drawings open in one session of autocad 2002, just wondering if it is possible to have another session open. Thanks.
RE: ACAD 2002 multiple sessions.....
Figured it out, if anyone is interested.
had to check "single drawing compatibilty mode"
TOOLS>OPTIONS>system tab
Which box of the tools>options>system tab did you make the correction?
System.
the variable is SDI
ADT 2004
Sorry to be more clear:
Tool menu > Options > Select the "System" Tab >
then in the general options box the first click box
make sure this is checked
>apply>ok
After this you'll have seperate sessions of autocad.
of course using SDI at the command prompt is much easier thanks Exxit
