Refrigerant Capacity & Charge
Hi Guys,
I have very small inquiry regarding converion of refrigerant charge quantity wrt its capcity.
E.g for cpmmercial window type AC, if I know the charge capacity of 50lb, how much would be its capacity in (refrigerant) TON?
Apprciated if I know the convertion details.
Thanks & Have a nice day!
Rahim
Rahim
RE: Refrigerant Capacity & Charge
The amount of charge has to be large enough so that all of the parts of the system that are supposed to have liquid in them have liquid in them under the worst conditions.
The amount of charge has to be small enough so that none of the part of the system that are supposed to have gas in them have liquid in them under the worst conditions.
The worst conditions for the two cases above are not the same.
A units refrigeration capacity is based on mass flow rate(lbs.hr) and the refrigeration effect(btu/lb) of the pound of refrigerant circulated.
I wouldn't publish papers on it tho...
