dissoving assemblys
dissoving assemblys
dissoving assemblys
Is it possible to dissolve an assembly that is within another assembly? Also, kinda the opposite of dissolving, is it possible to add parts to an assembly that are already present within the main assembly?
With solidworks, i could either use the disolve command, or just drag the parts out of the sub assembly, and into the main assembly, and vise-versa
thanks
Matthew
RE: dissoving assemblys
Its useful because i will sometimes find people making sub assemblys where all those subs need to be disolved to make just one assembly.
Right Mouse Button on the parts/assembly.
Hold your cursor over Component.
Select Promote or Demote.
David
Sometimes it makes sense to have subassemblies for construction purposes that are not needed in the BOM structure. If you open the BOM and change the BOM Structure from default to phantom, this will cause the subassembly not to show up in the parts list but instead the subassembly's constituent parts will be visible.
Look up Bill Of Materials in the help or go here:
http://www.augi.com/publications/hotnews.asp?page=1114
for a better explaination.
David
What if i wanted to keep them in there subs. Could i have one BOM generated from the misc parts, and subs?
Matthew
that promote/demote function worked great!
thanks a million
