Free Draining vs No Pockets
Is a line specified as "free draining" the same as one specified as "no pockets"?
RE: Free Draining vs No Pockets
Free draining would imply (to me) that there be no pockets and additionally no valves or other possible blockage.
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
and sloped if necessary.
Pockets must be able to be drained, either manually or other. What is the application? Pharma has other conotations or requirements to say chemical.
Mark Hutton
Free draining means that the line can totally drain in either  or both directions to empty the line.  No pockets means that there should be no liquid traps.  The resulting piping configuration described by these two notes will often be the same.
