auotprop custom propeties drop down 2
I like that autoprop macro and think it's excatly what we need with some massaging but have a few questions on it.
http:/ /cadimensi ons.com/zi p/SolidWor ks_Custom_ Properties _Automatio n_Tool.zip
Can it link to another file?
Reason we have #'s for our materials and it's quite extensive.
Could one put the material # in and have that macro reference another file with all the material descriptions or have it some where in that .ini file to populate our material description? Theres a password to edit the macro so I can't edit that fyi.
http:/
Grant
Applications Engineer
SW2008 SP 2.0
IBM InteliStation Pro M
Nvidia Quadro FX 3000
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: auotprop custom propeties drop down 2
Private Sub UserForm_Initialize()
Set fso = CreateObject("Scripting.FileSystemObject")
Set PropertyFile = fso.OpenTextFile("C:\property file.txt", 1)
Do Until PropertyFile.AtEndOfStream
ComboBox1.AddItem PropertyFile.Readline
Loop
End Sub
This should just populate a drop down menu with whatever you have in your text file. If that is what you are looking for, I can further develop this for you. Otherwise just let me know if I'm way off from what you were asking for.
How would you populate more than one property's drop downs using the same external file?
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
CODE
AB
CD
EF
<END>
*FINISH
#4
NONE
#2B
MIRROR
AS COMPONENT
SEE NOTE
BLACK OXIDE
<END>
*MATERIALS
ACRYLIC
UHMW-PE
WHITE DELRIN
AISI 304
AISI 316L
316L SS - 16 GA
316L SS - 14 GA
316L SS - 12 GA
304 SS - 14 GA
304 SS - 12 GA
304 SS - 10 GA
<END>
*SUPPLIERS
JACOB
ANY
CUSTOM
SPAENAUR
MCMASTER-CARR
REID
BOSTON GEAR
<END>
*DRAWNBY
AB
CD
<END>
*CHECKEDBY
EF
GH
<END>
Matt Lorono
Silicon Valley, CA
this is the one I meant.
http://
That all would be fine but the macro is locked with a password so i can't edit it unless someone knows the password or can tell me how to by pass it.
thanks
Grant
SW2008 SP 2.0
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
CODE
Dim strTemp As String
'design by
cboDesignBy.Clear
Open "C:\CustomProperties.txt" For Input As #9
strTemp = ""
Do While strTemp <> "*DESIGNBY"
Input #9, strTemp
Loop
Do While strTemp <> "<END>"
Input #9, strTemp
If (Left(strTemp, 1) <> "'") And (strTemp <> "<END>") Then cboDesignBy.AddItem UCase(strTemp)
Loop
Close #9
'finish
cboFinish.Clear
strTemp = ""
Do While strTemp <> "*FINISH"
Input #9, strTemp
Loop
Input #9, strTemp
If (Left(strTemp, 1) <> "'") And (strTemp <> "<END>") Then cboFinish.AddItem UCase(strTemp)
Loop
Close #9
'part materials
cboMaterial.Clear
cboMatPP.Clear
strTemp = ""
Do While strTemp <> "*MATERIALS"
Input #9, strTemp
Loop
Input #9, strTemp
cboMaterial.AddItem UCase(strTemp)
cboMatPP.AddItem UCase(strTemp)
End If
Loop
Close #9
'create list of Suppliers
cboSupplier.Clear
strTemp = ""
Do While strTemp <> "*SUPPLIERS"
Input #9, strTemp
Loop
Input #9, strTemp
If (Left(strTemp, 1) <> "'") And (strTemp <> "<END>") Then cboSupplier.AddItem UCase(strTemp)
Loop
Close #9
End Sub
I use this routine in the Form_Load routine to read my data file, populate combos and set up the form combo boxes values. Last two groups of data are used in a different part of the program. My data file allows comments to be inserted. That line has to start with "'" and it will be ignored by this routine.
