NX3 manufacturing - non-center cutting end mills
How would I properly set the engage settings in NX3 manufacturing to allow for proper cutting with a non-center cutting end mill in aluminum?
RE: NX3 manufacturing - non-center cutting end mills
You can use pre-drill engage points to tell the system where to plunge down to where you have already drilled a start hole.
Some tools although not center cutting can still cut using a helical engage at a shallow enough angle.
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
