Are MIL specifications out of date?
Does anyone use MIL specficiations anymore?
Mike
RE: Are MIL specifications out of date?
We occasionally use them when no other industry standard can be found.  I try to avoid them like the plague because most vendors automatically raise their price when they see a MIL spec.
MIL specs are still the main source a lot of items.  Even other standards will reference them.  It depends on which area you are in.  If you are using materials or documentation, I wouldn't personally callout the MIL.  However, if talking about hard shell shipment cases, I might refer to them.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
They are slowly being replaced mostly by ASME. If you look them up http://assist.daps.dla.mil/quicksearch/, it will tell you what they are replaced with and if they can still be used by new designs.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated 10-07-07)
There are replacments for these specs.
Chris
AutoCAD 06/08
The drawing lists ANSI Y14.5M.  Any reason that it has not been updated to the 1994 version?
As others said a lot of the MIL standards are gradually being replaced or at least supplemented by other standards, primarily ASME for this type of thing.
Normally a google search will turn this up.
  http://www.ipc.org/committeedetail.aspx?Committee=5-33e
Looks like the replacement for MIL-I-43553 may be a work in progress.
One other point on the drawing, you ref ANSI Y14.5M.  Current spec is ASME Y14.5M-1994 if that's what you mean to refer to.  By putting ANSI are you deliberately referencing the 1982 version, if so may want to add -1982 to make this clear.
KENAT, probably the least qualified checker you'll ever meet...
Ringman is correct. Clarification is needed.
Also, if a silkscreen house is doing this work, I don't think they will understand the MIL specs. Maybe split the dwg into two, one for fab and the other for silkscreen? Unless you do it all in house.
Chris
AutoCAD 06/08
We will update the ANSI spec...but this is more about the MIL specs.
If I understand you guys correctly, there isn't a non-MIL spec for the print yet?  This is a purchased part.
-Mike
There are a couple of Mil STD plating specs that don't seem to have an industry equivalent, such as anodizing.
Mike,
Did you search for your MIL spec in the link I attached above? It will show you equiv specs.
Chris
AutoCAD 06/08
Like I said, do a google search, that's where I got the link in my previous post from.
http://www.google.com/search?hl=en&;q=MIL-I-43553+replacement+for+
Obviously can't be 100% sure just based on this but it's a good indication.
Matt is correct. That is how I do it. I send silkscreener DXF file and a picture of what it should look like.
Chris
AutoCAD 06/08
