Amplitudes in shells
Dear all,
Is there a possibility to use different amplitudes for the different shell section points, e.g. for applying different temperatures to the section points?
Many thanks in advance!
Pinto
RE: Amplitudes in shells
yes,
you have to use composite section in shell, divide the shell thickness (say 100mm) into parts (say 5 parts), hence u will have 5 x 20mm thick of shell, u could apply amplitude to the shell with different temperature.
mambo5
