Prismatic properties from a 3D drawing
Attached please find a part of steel construction (3D) in dxf-format.
I intend to model the beam through CG of the object.
Beam looks like as shown in "3D element.dxf"
Can any one please help to find following parameters so that I can make a "Prismatic Properties" In STAAD.Pro?
The following prismatic properties are required for analysis
AX = Cross sectional area
IX = Torsional constant
IY = Moment of inertia about y-axis.
IZ = Moment of inertia about z-axis.
Bill
Bill
RE: Prismatic properties from a 3D drawing
