antiwater seal for high speed motor:11000rpm
Hi,all
I meet a problem of antiwater seal.
The customer ask to protect the hign speed motor(duty: 11000rpm/8hours) from water. The test method is just putting the motor in water statically. the water height is OK when it can cover all of the motor.The testing time is 5 minutes.
Many methods have been tried but in the end they all are not good because of this working high speed and antiwater test statically.
Any advices will be very appreciated.
Thanks.
Boyd
Thanks.
Boyd
RE: antiwater seal for high speed motor:11000rpm
Maybe a totally sealed magnetic coupling would work.
http://www.ferrotec.com/
Asking this question in the Pump Engineering forum may also be beneficial.
http://www.johncrane.co.uk/home.asp?r=uk&l=en
http://www.burgmann.com/
http://www.nashseal.com/Home/default.htm
