What did we use before encoders?
I have embarresed my self in front of a young electrical engineer. I can not remember the name of the analogue equivalent of an ecoder?
RE: What did we use before encoders?
You mean potentiometer?
If you're measuring angle then perhaps a resolver or an RVDT. If measuring speed then a tacho generator would fit the bill.
Thanks cottyUK,
It was a tacho that I was thinking of.
You can still get tach generators.  I just used one on a recent project as feedback on a shunt-wound DC motor.  They're getting harder to find now though.
A resolver is also an option if you want to get fancy.
Don
Kansas City
... or an inductive probe targeted at gear teeth.
- Steve
A resolver or a synchro?
In the good old days, mid seventies, I use to just use a magnet attached to a rotating shaft and a loop of wire.  Connect to a volt meter and wait for the needle to deflect.  Counting the spikes in a minute gives you RPM.  Same principle applies today, just fancier equipment.
Good luck at high speeds!
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
