NX5 - Untrim VS Enlarge
What are the benefits of Insert->Trim->Untrim compared to Enlarge surface?
It seems to me to actually give you less control over the resulting surface, and I am curious as to when Untrim be preferred.
Thanks!
Thanks!
Believe it if you need it or leave it if you dare. - Robert Hunter
RE: NX5 - Untrim VS Enlarge
I suppose enlarge could also be used in this instance, but if the underlying surface geometry is there, it seems like a better idea to use it rather than extrapolate a surface with the enlarge command.
One command is found under Edit Surface -> Sheet Boundary -> Remove Trim. This command will untrim a trimmed surface back to its original shape or area. Remove Trim will ONLY work on surfaces that are not Sewn to another body, unless you first Extract the surface you want untrimmed. Most users are probably familiar with this one if they have been working with imported surfaces that will not sew together and need to be untrimmed and retrimmed as cowski described.
The newer Untrim command has the capability of doing the same thing, except on a body with Sewn surfaces (so you can Untrim a solid face) and it's associative. Untrim essentially does the Extract Face and Remove Trim all in one step, regardless of the type of body.
Regarding the difference between Untrim and Enlarge, I'd have to say that Enlarge is different than Untrim in a couple of ways. First, you cannot use Enlarge on a surface that is Sewn to other surfaces, nor on a solid body face without at least making a copy or Extracting. Also, Enlarge allows you to shrink a surface's area, whereas Untrim only expands the surface but without any user input or control as far as how much to increase the surface's area.
I hope all that makes sense.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Some surfaces are B-Surface types and some just aren't planar surfaces are one example and NX also supports other surface geometry which is less frequently created by surfacing with NX that it is by translators bring in IGES for example. Enlarge surface does not necessarily respect that original surface geometry, whereas removing the trim does. However removing the trim may, as already mentioned, reveal that the original surface was still smaller than you require.
The is another function that can create surfaces larger that the original which is Isoparametric trim/divide. You are changing the surface geometry somewhat, but the surface internals are based on the original so the change may be minimal or at least more controllable.
Lastly there is trim and extend which I will only say does a fine job of extending one or more surfaces to a larger boundary, but does not necessarily respect the original surface geometry either. Nor or the internal edge to edge conditions always ideal. If you really want convenience and don't care overly about the surface geometry then this may be the tool for you.
Lastly you can create extension surfaces as separate sheet bodies and sew them to the original sheets if they don't trim large enough. Of the tools for doing that Law extension is probably the best. A law extension can be generated tangentially from trimmed or untrimmed edges of single or multiple surfaces, which is where it has the advantage over the other surface extension. This is great for creating extended shut lines for tooling or engineering surfaces that may be based on a styling release.
If you are unaware of it it can do harm to a styling surface if you mess about with the geometry. By all means take the trim off if you need to, but beyond that ask somebody if you are unsure.
John,
Any reason why we can't simply extend a planar or other regular surface type such as a cylinder without turning it into a B-Surface which is thereafter treated as inferior as regards mating etc. The geometry is simple therefore it begs the question why the work process is not?
BTW I know there will an answer in the technical background but I'm not interested in that. I just want it to create a planar untrimmed rectangle that I can pull wider and trim back to suit without having to do a bunch of extra steps. the temptation at present is for some operators to take shortcuts and devalue the result often without due consideration for the consequences.
Best Regards
Hudson
Untrim
What is it?
The Untrim command removes imposed boundaries. It extends planar, cylindrical, and conical faces in the linear direction of the selected face, and cylinders and cones along their axis.
With the Untrim command, you no longer have to extract multiple faces and then extend each of them. You can use the command to perform additional modeling tasks on a specific region of an existing model.
Where do I find it?
Choose Insert?Trim?Untrim.
I don't mind taking the credit if no one else is gonna give it to me. Absolutely no offense to my bud cowski intended at all. :)
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
This might be what I'm asking John for, I'll have to dabble and get back about it.
in as far is it goes for free-form surfaces my earlier post will probably remain valid since a linear extension would be unsuitable in most cases.
Best Regards
Hudson
Any reason why we can't simply extend a planar or other regular surface type such as a cylinder without turning it into a B-Surface...?
About the best you can do is an 'Untrim' and hope that the face created is large enough for you task. However, that being said there is one more thing that will give something the might be good enough. Have you ever considered performing an 'Axisymmetric' Scale Body along either axis of Cylinder or a vector in the plane of the Planar surface?
John R. Baker, P.E.
NX Design
Cypress, CA
Best Regards
Hudson
John R. Baker, P.E.
NX Design
Cypress, CA
Can you then mate a flat planar underside of a bolt head or the flat face of a washer with a b-surface using the mate command?
Best Regards
Hudson
John R. Baker, P.E.
NX Design
Cypress, CA
That's two things I have to check out based on the one thread. Going well :).
BTW, I'm using your NX-6 image as the desktop just to freak people out. See how many grab the spaceball
Best Regards
Hudson
You are correct, I was (unintentionally) referring to the Remove Trim command and not the new Untrim command. My apologies to all for muddling the conversation.
If I need a larger sheet body, my first attempt would be to adjust the defining strings. Sometimes this introduces unwanted side effects or is impossible (ie imported geometry). My second choice is "remove trim" (and now the new "untrim") since they are based on the underlying geometry. I consider "enlarge" to be the last resort since (as has already been mentioned) it can deviate from the original surface and can introduce self intersection or consistency errors.
Tried and liked the new un-trim command. It seems likely to serve well in most cases though perhaps not all.
John,
You encouraged me to look at the new component constrains as opposed to mating. I see that they resemble something that I've seen elsewhere and appear to work quite well. I haven't has time to test degrees of freedom as compared with mating so I don't yet know the state of play there. Apart from that the method you described works well and adds to the armory of things we could now do that we couldn't previously, but it seems to come at some price.
Why oh why do they have to be completely separate from mating and in fact to cancel out your ability to even have mating co-exist with them. I can't see the need for this based on a straight comparison between the two. Please consider if there isn't still time to implement the capacity for current mating conditions to be redefined automatically as new assembly constraints. I really think that all the methods available to mating need to be carried over to constraints and that a direct translation ought to be possible.
I guess there is a technical reason that enabled you to introduce the new functionality earlier I would take that as read. What I see is two tools where there ought to be one and a compromise that I'm disappointed with.
Best Regards
Hudson
As for mixing and matching, it's just NOT possible, period. The old Mating Conditions were order dependent, much like a history-based feature model that plays back a recipe or tree, while the Assembly Constraints are more like the sketcher were the relationships are solved as a series of simultaneous equations. The order of creation is not important and if a change is made the entire model is resolved, just like a sketch (which is why sketches are created in a separate task environment).
Not sure what you mean by seeing multiple tools where there should be only one? If you're referring to having BOTH Mating Conditions and Assembly Constraints available, that will be resolved soon enough.
John R. Baker, P.E.
NX Design
Cypress, CA
Okay my mistake if I'm wrong but how CAN I convert mating conditions to constraints? If it is possible without re-selecting anything then I hold NX in high esteem. Even more-so if degrees of freedom and the sort expression driven simple motion that I used for the engine are also possible. In that case I'd be on-board to simply say out with the old and in with the new
Best Regards
Hudson
Bill
First, we do not attempt to automatically convert Mating Conditions into Assembly Constraints when an old assembly file is opened in NX 5. Even though all of the parts get their internal data structures upgraded when an older part is opened in NX 5, this is NOT done with Mating Conditions. There are a couple of reasons for that, such as when an assembly file has been released and there's no need to make any further changes to the assembly, there is technically NO need to do a conversion since while it is true that you can't mix Mating Conditions and Assembly Constraints in the same part file, there are no problems having an assembly created with Assembly Constraints which contains sub-assemblies created using Mating Conditions. This way users can take existing released sub-assemblies and reuse them in their latest assemblies.
Now as to how one goes about actually converting a pre-NX 5 assembly so that the Mating Conditions are upgraded to Assembly Constraints, you must first switch NX 5 over so that Assembly Constraints are now the default scheme. You can do this in Customer Defaults -> Assemblies -> Positioning -> Interface and set the Positioning option to Positioning Constraints. Note that once this has been set, when you launch NX and open a file, on the assembly toolbar the Mating Conditions icons will have been replaced with Assembly Constraint tools. Note that you can temporarily set the system, at least for your current session, back to Mating Conditions, by going to Preferences -> Assemblies... and set the 'Assembly Positioning Interaction' option.
Now, with the system set to Assembly Constraints, open your existing pre-NX 5 assembly (you can use partial loading if you wish) and once open, simply select the 'Assembly Constraints' function either from the Assemblies pull-down menu or the Assemblies toolbar. After selecting the function a warning message comes up telling you that the assembly contains Mating Conditions and asking whether you want to convert them or not (note that you can ignore this message and continue leaving them in place and build new constraint on top of the old ones since these schemes totally ignore each other like they were never there, but it is confusing so I'm not sure I would recommend that anyone work that way or even try to). If you select the convert option, a dialog will come up which offers some options like only converting the Work Part level only (ignores the internals of any sub-assemblies), or the Work Part and any open children, or Work Part and all referenced parts (which means that it will automatically open any unopened yet referenced part files). Also there are some options about whether you want to get a summary or a full report afterwords, etc.
Anyway, I just tested this on a modest assembly, 160 components in 3 files (the main assembly and 2 sub-assemblies) which was modeled in Unigraphics V14.0 and last updated in Unigraphics V17.0 a bit over 7 years ago. The conversion took maybe 45 seconds and 333 constraints were converted with no errors.
John R. Baker, P.E.
NX Design
Cypress, CA
I'm starting to like what I see. It took me a few days until I had time to check this out and respond. It is evident that you can convert some be not all mating conditions to assembly constraints. This it does but not quite flawlessly, perhaps some of the kinds of mating conditions I was using in the past are not supported in assembly constraints as a direct conversion, but may need to be reapplied using a different method. I managed to get a small example piston and crank engine to convert and it appeared to work first time. The larger more complex Stirling engine failed, perhaps all the universal and ball joints were always going to stretch the automatic conversion.
I'll find out eventually whether each works but for now I just wanted to take the time to acknowledge and thank you for your post. Perhaps there are further improvements also in NX-6 that will demand our attention. As of NX-5 the change doesn't appear to have been widely adopted or taken notice of among my colleagues. I hope for that reason that the converter will remain in place for a couple of versions to come at least. I'm sure that you'll eventually want to de-support the older code.
Best Regards
Hudson
If you wish for an example of what this may end up being like, if you go back this far you many recall that we continue to properly update any model which contains what we call 'pre-V13 sketches', and we even allow you to go into one of these obsolete sketches and make edits (but you will need to find and turn on a special Icon for just that purpose), but there is NO way in which you can CREATE a NEW 'old' style sketch. But if you edit an expression used by that obsolete sketch it updates just fine.
To see what I mean, attached is a part file that I still use today in my main-stream demo but which was created back in Unigraphics V10.1. It was build around a sketch which was then extruded into the final model. Now if you open the Part Navigator, while you see the Extrude features there is no sketch apparent. Granted, if you were to 'Reverse Blank/Hide' all of the model you'd see the sketch curves and even the datums used (which are also of a style no longer 'supported' yet still honored) by it, but you would also discover that you can't actually edit the sketch, at least not by selecting it and pressing MB3. I'll leave you the exercise of finding the special icon that will provide access to the sketch itself
Anyway, I hope that helps you understand what our policy is toward old and eventually obsolete features and functions.
John R. Baker, P.E.
NX Design
Cypress, CA
Yes I go back a way before V13, and I know about the icon for the pre-V13 sketches. Rarely used these days I must say, but good to know it is there when needed.
What I was happiest with is the presence of the converter. As I said there seemed to be some mating conditions that I couldn't convert and I did wonder how I am supposed to find them to analyze what I need to do to remedy that situation. It says that is was unable to convert some mating conditions and so it left them in place. But since mating is replaced by constraints everywhere in the icons and dialogs I no longer seem to be able to get into the mating conditions to check what is missing. Also I'm still a bit unsure about the presentation of the constraints since they don't appear to be collected in the same way as mating conditions how do I find out what constraints are applied to each object and manage to quickly analyze whether each component has degrees for freedom or not. Lastly the hide show needs to list constraints as one of its entity types to quickly blank and unblank. I think in NX-5 that hasn't been done yet.
I really want to work through that Stirling Engine and get it converted to constraints as an exercise for myself in coming to terms with the new functionality.
We often cover ourselves by asking the sorts of questions that I put earlier about backward compatibility, our worst fears are usually unfounded and that is laudable in itself. But the other side of that coin is that having the tools to make a transition from one method to another is often a big ask yet because in this case the two are notionally similar I think it is not only most appropriate but also very well done to take on that task and make it work. There are times when I have pondered the value that is being added from one version to the next for current users as opposed to changes which may make NX more marketable to users coming from other systems. This particular feature probably straddles both but I do think the new one will be better and I think, if the converter meets with pretty much universal approval as I think it might, that the existing users are being looked after as well.
BTW nothing was attached?
Best Regards
Hudson
As for getting access to the Mating Conditions, you can switch back and forth by going to Preferences -> Assemblies... and at the bottom of the dialog there is a section titled 'Assembly Positioning' and there is an option item there where you can switch from 'Positioning Constraints' to 'Mating Conditions'. Note that this will only be in effect for this session and will revert back to what you have set in Customer Defaults. While this option is set the system will display the appropriate Icons and Menu Items as well as honor the particular assembly scheme, Mating versus Positioning.
When you say Hide/Show constraints I assume you mean as seen in the graphics window superimposed on the model. If you go to the Assembly Navigator and select the top item titled 'Constraints' and press MB3 you'll find an option to Hide or Show all constraints.
As for seeing which constraints have been applied to what components, open the Dependencies panel of the Assembly Navigator and with the 'Detailed View' open toggled on (the little magnifying glass in the upper right of the Dependencies Panel) when you select a Constraint it will show you the Components that it's applied to, and if you select a Component it will show which Constraints are applied to it.
As for discovering the degrees of freedom, that's the only thing that we haven't worked out a new mechanism to show that yet.
John R. Baker, P.E.
NX Design
Cypress, CA
I had thought that the only way was to use the customer defaults and re-start NX. Now I'll be able to check out which constraints didn't work.
With the hide show thing. Yes I knew but I thought it would be a good idea to mention it for inclusion later under the other icon which is a great convenience which I really warmed to in NX-5.
The arm looks familiar. And yes the pre-v13 sketch tool does work which is a good thing in itself. What always interested me with that and the reason that I wanted to applaud your approach in changing the mating to constraints was in fact that this time there is a conversion utility. Whereas for the pre-V13 sketches there was not even though they are also notionally similar entities. I think I prefer the converter simply because you're not left with legacy features when things change.
This may seem like a moot point about the pre-V13 sketches at this late date, but I didn't want you to miss my point about why I liked the idea at least of having converters supplied when things change as an enabler for people with existing data to bring it up to date quickly and easily. I think that existing users are better served when this is the case and the scope of what it is possible to revise in the the software without compromising the so called "legacy data" may be increased in that case.
Best regards
Hudson
Yes, I agree about the conversion issue, and it's possible that if we were doing this over, we might have been able to write a sketch converter, but back then, with the resources that we had and the other priorities on our plate, it was not possible so we had to go the way we did. However, we are much more skilled as updating and converting data types since our effort to convert the Ideas data models into NX data models. When you have no choice (and in that situation, WE HAD NOT CHOICE), it's amazing what you can do with the resources that you have. Of course, we had at our disposal the combined talent of the the Unigraphics and the Ideas teams and they came together with one thing in mind and we accomplished what we set out to do. And as I said, it gave us better insight into the procedures needed when converting one complex data type to another. Now this does not mean that we will have as much success with all future situations like this, but at least we know more now than we have ever known and it should help.
John R. Baker, P.E.
NX Design
Cypress, CA
Agreed 100% no beef with ancient history, just acknowledging that it is a good thing and noting the idea of having the ability to convert may be an enabler for changes that do involve redefining legacy data in order to take on new methods.
Best Regards
Hudson
