Updating code
Updating code
I have written a VBA code and it works perfectly fine untill I insert an entire row to the exisitng sheet. The code doesn't work for that new cell I have inserted but works fine for other cells. Any suggestion are apprecited.
Ghouse
Ghouse
RE: Updating code
RE: Updating code
Private Sub CheckBox1_Click()
Range("C5").Select
Do Until Selection.Offset(1, 0).Value = ""
Selection.Offset(1, 0).Select
If CheckBox1 = True Then
If Selection.Value = Range("I5") Then
With Selection.Font
.ColorIndex = 3
.Bold = True
End With
End If
Else
Selection.Font.ColorIndex = 0
Selection.Font.Bold = False
End If
Loop
Range("C3").Select
End Sub
Would you provide me the link to VBA forum.
Ghouse
RE: Updating code
