Previous Thread About Immovable Part In TL Assy?
There was a thread recently about a part which could not be moved after being inserted into an assy. Adding mates allowed it to be moved, and moving it into a sub-assy allowed it to be moved within that sub-assy. I cannot find that thread but believe I may have at least a partial answer.
It appears that sometimes the Lock Mate option is automatically created upon insertion of a part. Normally the Lock Mate can be seen, but I was experimenting over the weekend and found that even if the Lock Mate was intentionally created and then deleted, the part was still locked in place, even though no mate was visible. Moving it into a sub-assy freed it. So I'm suspecting that this may be a bug, where SW is placing the part into a locked state without the Lock Mate showing.
Anyone else experienced anything like this?
RE: Previous Thread About Immovable Part In TL Assy?
http://www
I've inserted the odd part into a TL assembly and then found that it had been fixed when I tried to roughly position it prior to assigning mates, which isn't the usual behaviour, but RMB "Float" cured it. I think that the problem you describe is peculiar to 2008 (I have been waiting for a suitable 64-bit driver for my VC, seems to be there now so must take the plunge!)
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
Cheers
Thanks for posting the thread link.
digger200,
RMB = Right Mouse Button.
CBL,
Thanks for the star and answering the RMB question.
digger200,
Your other "annoying thing" about switching between open files, sounds very similar to a bug discussed on this thread last month:
http://www
