Custom Properties Drop down
I am in the process of adding custom properties to our starter templates and wanted to know how to populate the drop down box on the value field to have a few selections for the users to pick from.
We are currently running SW 2008 sp3.0
-Joe
SolidWorks 2008 x64 SP 3.0 on Windows XP x64
Dell Percision 490
Intel Xeon 5160 @ 3.00Hz (Duel Core)
8 GB RAM - Nvidia Quadro FX1700 (6.14.11.6262)
RE: Custom Properties Drop down
The drop-down selections are read from the properties.txt file which (for SW2008) is located at C:\Documents and Settings\All Users\Application Data\SolidWorks\SolidWorks 2008\lang\english.
You can add whatever properties you need directly into that file.
Do you have a blog or would you like to member of a current blog with multiple contributors? You have a lot of good input on this board though could make good articles. Let me know. See SolidWorks Legion in my links of my signature. We currently have three contributors.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
I do not have a blog. I am more a find-a-solution-to-the-problem guy than a publisher of information ... a fighter not a writer (Gilbert O-Sullivan).
If I ever find a topic I can expound upon I will fire you a copy for inclusion to the Legion.
Thanks for the kind words.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated 10-07-07)
tristram "wanted to know how to populate the drop down box on the value field to have a few selections for the users to pick from."
Example:
Property Name = Material
Value/Text Expression = Stainless Steel
Galvanized Steel
Aluminum
The user would be able to select a material from the list. Please correct me if I'm wrong, tristram.
The one I used was from our Var's website here: http://
The best thing is it is fully customizable which the text file describes how to do. I think this may be more of what your looking for. Let me know...
Best Regards,
Jon Knabenschuh
Gemini CAD Solutions
http://www.geminicadworks.com
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2007
Good catch ... I totally skimmed over that detail.
That has been asked before ... a long time ago. I don't think an answer was ever given.
I will look into the macro that CADGemini provided when I get some free time later (most likely when everyone else has left)
-Joe
Dell Percision 490
http:/
The one I posted is similar in nature except that it is built into the feature manager.
I guess it all depends on the look you want the end user to see and how much information you will be filling out for each type of SolidWorks document. I am sure either one will do the job and then some.
Best Regards,
Jon Knabenschuh
Solidworks 2007
Thanks for the site address. GoEngineer is our VAR also. I just never thought to look there. A star for you.
Bradley
SolidWorks Pro 2008 x64, SP3.0
PDMWorks Workgroup, SolidWorks BOM,
Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB,
nVidia Quadro FX 3400
Use SolidWorks BOM
e-mail is Lotus Notes
Thanks for the star....
where you located? I'm in Utah.
Best Regards,
Jon Knabenschuh
Solidworks 2007
I am in California.
Bradley
Use SolidWorks BOM
Best Regards,
Jon Knabenschuh
Solidworks 2007
I like the one from GoEngineer, but that one does not have the properties configuration specific. All of our models from the get go have the properties configuration specific. So far that is the only free property macro that is easy to modify and has the properties config specific.
http
There is one other one, but it is modified by XML and that is foreign to me.
Flores
You can make the properties configuration specific with the Go Engineer one by the parameter CONFIGURATION SPECIFIC=YES or No which is under the Header.
I haven't had any trouble setting this up but maybe it wasn't coded into the macro when it first came out.
Best Regards,
Jon Knabenschuh
Solidworks 2007
Being added to the FeatureManager pane is something you can add to your macro. You can look it up under the API help if no one else responses here. I personally don't like using the FeatureManager pane for this type of macros. I've used a custom macro similar to the one uploaded here:
http:
Matt Lorono
Silicon Valley, CA
-Joe
Dell Percision 490
Best Regards,
Jon Knabenschuh
Solidworks 2007
I like the interface from GoEngineer's macro better.
It is similar to the one from this site: http://www.swcp3.com/ but we didn't use it because you cannot have a space between the property names. For example we use "Modeled Date" and others choke on that blank space between the words.
Flores
-Joe
Dell Percision 490
Matt Lorono
Silicon Valley, CA
You could just enter a space for the properties that have no value. I guess this is a workaround but your right they should be able to accept no value at all.
Your users will also have to remember to backspace before typing in values otherwise when they are imported into the drawing things could be off by a space.
Best Regards,
Jon Knabenschuh
Solidworks 2007
