micro stirling engines?
Does anyone know if a very small stirling engine is made? I need to dissipate 800W of heat from a surface 5mm square and need to keep the stirling engine small (as in very small) Can any of you point me to something that would fit the application?
RE: micro stirling engines?
http://ntrs.nasa.gov/search.jsp
ht
In its infancy unfortunately.
Here are some additional site that may be of help.
I think it would well worth the effort to give Metafoam a call. The may not have a working system but could possibly point you in the right direction.
http://www.metafoam.com/500W.html
These two companies are mentioned in a lot of literature on working with heat pipes especially in cooling
http://www.thermacore.com/
http://www.1-act.com/index.html
Here is a Magazine that may be of interest to you.
http://ele
