Random Wound Air Coil Calculations.
I am looking for a site with the correct Inductance Calculations & Dimensions for the calculations for Random wound air coils.
Do i use the same calculations as single layer spiral coils, there are many different inductance calculations for flat wound spiral, multilayer etc but i am unsure of the Random wound type?
Any help would be greatly apreciated.
RE: Random Wound Air Coil Calculations.
Voltage gradients and capacitance are an entirely different matter altogether, but that has nothing to do with the inductance.
If this is a dc solenoid it does not matter, scramble winding will be fine.
If it is a high voltage, or high frequency winding, it could matter rather a lot.
Thank You Again.
http://home.earthlink.net/~jimlux/hv/wheeler.htm
