pressure/temperature ratings forged steel valves
What is the temp rating on a 2" 800# class A105 globe valve
@ 1975psi?
@ 1975psi?
pressure/temperature ratings forged steel valvespressure/temperature ratings forged steel valves(OP)
@ 1975psi? Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: pressure/temperature ratings forged steel valves
I assume that the quoted class 800# should be a missprint, either class 600# or 900#, in accordance with API 6D. Please find below an "extract" from the API6D, ed. April 2008, Clause 7.2:
"Pressure-temperature ratings for class-rated valves shall be in accordance with the applicable rating table for the appropriate material group in ASME B16.34.
Pressure-temperature ratings for PN-rated valves shall be in accordance with the applicable rating table for the appropriate material group in EN 1092-1.
If intermediate design pressures and temperatures are specified by the purchaser, the pressure-temperature rating shall be determined by linear interpolation.
Pressure-temperature ratings for valves made from materials not covered by ASME B16.34 and EN 1092-1 shall be determined from the material properties in accordance with the applicable design standard."
Since the 1975 psi is exceeding the class 600# alltogether, then the temperature rating for 1975 psi in class 900# would be some 235-236 F, group material 1.1, as per ASME B16.34.
cheers,
gr2vessels
(1) Class 800 is not a tabulated ASME B16.34 designation. It is an intermediate class that is widely used for socket welding and threaded end valves.
-MJC
Here is there statement on pressure temperature ratings and a link to the current catalogue.
2.5 Pressure/Temperature Rating
Proper selection of the pressure/temperature rating of the valve shall meet service requirements. If the valve application involves temperatures above 100°F (38°C), then the valve pressure rating at the service temperature must be verified to meet the requirements of the application. If system testing will subject the valve to a pressure in excess of its working pressure rating, then the intended testing pressure and a statement explaining whether the
test pressure is through the opened valve or a differential across the closed valve, should be included in the purchase
specification.
Source Reference for Vogt valves pressure/temperature ratings ASME B16.34 Valves, Flanged, Threaded, and Welded End VVACT0000, Vogt Catalog.
Vogt catalogue page 112 for pressure temperature ratings.
ht
Thanks also for the guys to help...
cheers,
gr2vessels
