How can I sort the drawing sheets in part navigator
Hi All,
If you see in part navigator, under drawing header, if I add more than 9 sheets , the order of sheet creation is a mess. Ideally speaking , sheet no. 10 should come after sheetno.9 ,but it goes above sheet no.1 , same is the case when you add sheet 20, it goes above sheet no.2 .. Please can any one suggest as to how I can make it in ascending order?
RE: How can I sort the drawing sheets in part navigator
Put a zero, '0', in front of any single digit name such as 'sheet no. 01', 'sheet no. 02',....'sheet no. 09'.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Thanks for the reply John.. I has really helped me
