lambda problems
lambda problems
I did a Turbo conversion on Saxo 1,4 , 8 valves.
And I also changed injectors .
But now the problem occoured , that lambda sensor is not giving enough voltage 2 computer and to air/fuel meter ( gauges) .
It is shown as poor mixture , while exhaust is black , spark plugs are black, and everyone can smell gas on exhaust pipe.
( 2much fuel )
I changed lambda sensor with new : no change .
I changed lambda sensor with 4 others : no difference .
And as I measured, Lambda is constantly giving 0.185 Volts ( 2 poor mixture ), instead of cca 0.500 Volts ( normal mixture ).
Voltage for lambda heater, that I measured, is 11,75 Volts ( normal ? ).
At first I had placed Lambda before turbine .
Than I placed it after Turbo .
Still no change .
This problem occoured , exactly when i changed injectors .
But even before that, the car was not running smooth at low RPM's ( low idle, 2000 RPM ).
The computer is Magneti Marelli IAW 1AP 40 .
I had 2 change fuel map , to make the car running .
Before that it was even not runing .
I was wondering,if anyone has another idea, what is wrong ( why is too weak lambda signal) until I'm waiting on my friend-expert 2 come from Italy 2 Slovenia ( my country), on/in Monday.
Thank you 4 helping me .
Boschtyan
( 2much fuel )
Still no change .
Boschtyan
RE: lambda problems
You say you changed the fuel map, so apparently you have a means to modify air & fuel parameters in the controller. But the modifications have to be made based on data. Trial and error will take a long time. If your friend-expert has done this successfully before, I suggest you wait for him to arrive and learn from his experience.
RE: lambda problems
I have also changed Peugeot 206 1.6 , 8 v into Turbo engined.
And it was very easy + big success .
Also I did it on VW 1,6 Diesel .
And Fiat 1,4 is included .
And this my friend has never done Turbo conversions like I am doing .
But now my knowledge has gone . So I'm still waiting on my friend, because he has other experiences + knowledge.
But in the meantime, I was wondering , if maybe you have some other ideas ( till Monday) ?
Again thank you 4 your cooperation + may Lord bless you.
Boschtyani + #
RE: lambda problems
RE: lambda problems
RE: lambda problems
Also, if you're running so rich that the engine is misfiring your sensor will read lean (low voltage) because of the unburned oxygen in the exhaust. This is common tuning problem and the tuner will usually add fuel because the sensor reads lean; making the problem worse.
RE: lambda problems
In the script, there was shown, that the "signal" is coming from the Grey cable .
But, mistake ; it is Black cable, that is giving the right voltage .
Now, as I changed cables, it is working properly, and showing very rich mixture .
O.k. from now .
So, in the afternoon i also remaped chip ( againnnn,... in sixth time , heh ).
Now, since AFR meter is working as it should, ... another problem is showing ( I hope, that there won't be much more problems... ).
The AFR meter is jumping up + down , as we all know at low idle . ( at higer RPM + 1.5 Bar of Boost it becomes still )
But in this case , AFR Meter is also jumping at 2000 RPM , at "cruising mode" .
But the main problem is, that engine is having the same trouble as showed on indicator : it is shaking like hell .
But, as I remembered, this the same problem, was there all the time - even before i did this Turbo modification.
It's yust, that now it has increased much more obviously .
So, I think, that the Computer is not delivering constant mixture , as it is shown in AFR-Meter, because it is jumping right sinchronized with "jumping" of the engine .
It is really hard 2 drive, because engine is constantly pulling forth + back , at "cruising mode" . ( some mess, ... eh )
Maybe any another idea , what I can do to repair this cheap computer , to get it work more smoother at middle/low range ?
Like before I really thank you 4 all your help .
May Lord be with you .
Boschtyan from Slovenia .
RE: lambda problems
I also tought , of computer "misfiring" lambga signal . But since yesterday, i know , that I it was not hapening .
Thanks 2 Lord 4 that.
And , as you, many others also told me of buying wide-band lambda sensor .
But I think, that - because I wont go over 200 HP/Liter, ( 280 HP in this case of 1400 CCM, 1.4 L ), that won't be needed .
I consider this only " a small tuning" .
For me , a "bigger" engine tuning is over 200 HP/Liter .
Today , I will be changing wiring on injectors , because now I have right oposite way : 4-3-2-1 , instead of 1-2-3-4 .
This happened, when I changed injectors , and I had no spase left for connectors .
So I had 2 turn all cables with connectors in oposite position ( upside-down ) .
Maybe also this is one of reason, that there is no good combustion ( because of timing of injection ).
Till next time ...
seee yaaa
Boschtyan, EU
RE: lambda problems
RE: lambda problems
have never tried this but can,t see how reversing polarity would cause inj. too stay open or closed.
RE: lambda problems
RE: lambda problems
RE: lambda problems
RE: lambda problems
Bob
RE: lambda problems
Kopron, if you're running boost you should be running too rich at WOT for a narrow-band lambda sensor to read properly.
Here's an experiment for those that think injection timing has a big effect...On one of our single cylinder quad engines, the ECU blew-up and would not open the injector. We ran a power and ground and you could keep the engine running by tapping the ground lead to the chassis to open the injector.
We also played with injection timing on our four-cylinder sequential setup and could not measure a difference in hp.
RE: lambda problems
RE: lambda problems
The only diference was in Bosch ( motronic ) computer which we also remapped.
RE: lambda problems
And only in this case, which is "simetrical" wiring, ( 2 outside + 2 inside ) changing the sequence from 1234 to 4321 makes no diference .
See ?
But now , as I changed wiring, it has shown as I predicted , that there is no diference .
Now we move on . Today I will replace fuel-pump with "stage 2" Cosworth .
I hope , that I will manage 2 do it, because it is much bigger than original pump . ( like 3.5 times )
And it is inside the reservoir, so even more trouble on the way because of less space .
Hear ya till next time .
Till than, may Lord be with you .
RE: lambda problems
I would end this case, because we' re going on MegaSqirt computer, because this MagnetiMarelli has some bad extra maps in it, and it is not working as it should. I hope, that with MS we will solve the problem ( problem of unconstant running of the engine at low power ).
See yaaa, somewhere
Boschtyan Zupanchich, Slovenia, Europe,
RE: lambda problems
As for some of your problems with engine surging you might run your O2 sensor into a opamp set to zero gain with a delayed feedback loop so the controller sees an average of the last few signals, this might calm the computer down a bit so it isn't chasing every transient signal it sees.
RE: lambda problems
Thanks.
RE: lambda problems
The easiest way to tell if the closed loop system is your culprit is to simply put the vehicle in open loop and see if it continues to oscillate. I would recommend doing this only under light loads (you stated it occurs under cruise conditions).
RE: lambda problems
But I didn't understand , what you suggest as solution . Loop = ? ).
Maybe you tought ; If I tested it without Turbine .
But I did, and problem was remaining the same.
Or there was something else that you were thinking about ?
Have a nice day .
Bostyan .
RE: lambda problems
RE: lambda problems
Have a nice day .
In Monday we'll continue.
Till thannn, ... may Lord be with you .
C' yaa.
RE: lambda problems
RE: lambda problems
But, now, after this past weeks, we mounted MS.
And, a si predicted, it runs smooth almost as it should .
There are yust small "misfires" of the tacts-strokes, bu at least i can drive car normally, without small fast jumping oscilations.
And, so far on 1,5 Bars , it runs very very smoothly .
Next week we'll go on to 2.5 bar of boost.
So, the problem really was in the computer, a s I tought.
Well, next time, when i will go to a similar project, i wil be much much more careful, which computer the car will have.
Unfortunatelly, you can't know that, before, when you lower the compression ratio. Than this problem occour.
But never again I will do this on the same kind of car. Never.
Anyway, I gratefully thank you 4 your help + your time + cooperations + support , and I'm closing 4 now.
Bye, ... see yaaa, brothers, ... if not in this life, than "on the other side",
Boschtjan Zupanchich, Slovenia, Europe, Earth, ...
+ may Lord be with you.
