Local stresses for attachment inside the cylinder
Hi all
I am wondering if we can we do local stress calc. for the attachemnt welded inside the shell per WRC 107 "local stress in spherical & cylinderical shell due to external loads". Calc is to be run for the bed support beam clip welded to I.D of shell. I have found that this bulletin addresses the attachment to the outer surface of shell only. Pls Suggest. Thanks.
RE: Local stresses for attachment inside the cylinder
Similarly with WRC 297.
Is this the same result to WRC 107? Please comment.
