Starting license server in vista ultimate
I have vista ultimate 32-bit, and I tried to install Abaqus v6.7.1, everything goes smooth, but commencing license installation, there's a note that abaqus can't start service in vista and check answer 3392 on abaqus website for further workarounds, which I couldn't find.
Does anybody know how can I start the service manually while the licensing tools are installed.
It's interesing that I have installed Ansys Sp1 too and it works smoothly and its service is started automatically
RE: Starting license server in vista ultimate
Then select Start/Stop/Reread tab and click on Start Server
when clicking start lmtools responds "Server Start Failed. The Server May Already Be Running!!".
I have already tried to add the port and the lmgrd.exe to firewall exceptions, and in the administrative tools->services when I try to start the service manually windows gives error 1053, the service can not be started.
It is there - login to the online support system, and go to the Answers tab. Now do a search on the ID, '3392', but make sure that you change the 'Search By' dropdown to 'Answer ID'.
Anyhow, link to the answer..
http://tiny.cc/Us0Aw
Martin Stokes CEng MIMechE
