Webs between spline points?
I seem to have a spline display problem--perhaps it's a line font (or other) issue. Check out the images I've linked and let me know if you know how to eliminate/hide the lines connecting the points of my spline. I've never had this happen before.
At first, SW wouldn't let me select or delete the lines, but would then act as though they were real by not letting me extrude the simple spline as a surface. I opened a new part to check if I could do it then, and it let me. I returned to my original part, and it worked, but I still had the webs.
http://www .industria ldesignhau s.com/inte rnet/Splin e-Webs.jpg
http ://www.ind ustrialdes ignhaus.co m/internet /Spline-Se lected.jpg
http:/ /www.indus trialdesig nhaus.com/ internet/S pline-Trou ble.SLDPRT
Thoughts? Do you see the webs in the sample part provided (maybe it's my system)?
http://www
http
http:/
Jeff Mowry
www.industrialdesignhaus.com
What did you dream? It's all right--we told you what to dream.
--Pink Floyd, Welcome to the Machine
RE: Webs between spline points?
Thanks for the check and reply!
Jeff Mowry
Jeff Mowry
Or maybe even try the latest and greatest from ATI.
Jeff Mowry
Jeff Mowry
To ATI--you guys are weird.
Jeff Mowry
