user defined settings
IT is going to "reload" NX for me (due to other problems for another thread) and I'm wondering if there is a file (or files) with my user defined settings that I can "grab" before this takes place and then "replace" after the reload? I'm sure there is, but what and where, not sure. any help would be much appreciated.
Patrick McCracken
CNC Programmer
RE: user defined settings
BTW if they re-install you OS you'll lose your icons if they just re-install UG then they shouldn't be affected, as they live elsewhere.
Best Regards
Hudson
And: http://plmexchange.net/customer-defaults/
When you start up NX look at the log file, search for the environment variables in the links above and copy your user specific settings.
Depending on the size of your company, I would look at having this set on a shared location so machines can come and go, but your settings will stay persistent to your login (on any machine).
-Dave Tolsma
Tolsnet LLC
http://groups.google.com/group/NX_CAX/
http://groups.google.com/group/plm-exchange/
Patrick McCracken
CNC Programmer
