SDRC Emboss Feature
SDRC Emboss Feature
SDRC Emboss Feature
When I attempt to use emboss the embossed feature is not closed. How would I rectify this?
thanks
RE: SDRC Emboss Feature
First check that the section used in the emboss is closed, anyway you can select Wireframe and create a new one.
Good Luck.
Change the draft angle.  You will have to play with this to get no free edges.
