temperature in solid composite layup
Hi all,
would that be possible to put temperature into every layers of the solid composite layup?
I have a 130mm thick slab, built up with solid elements, I divided the thickness into 10 layers (13mm per layers), i would like to apply different temperature to every layers of the slab, i.e 20oC to the 1st layer, 100oC to 2nd layer, 200oC to 3rd layer....
I used the ABAQUS CAE, propety - create composite layup to define the layers in the slab, i not see any option for 'adding temperature', please advise.
