Deep hole drilling + ball-end fillet?
Hey all,
I have a question as to whether or not this feature is (reasonably) machinable. I have a 8mm OD tube, approximately 180mm long, and I need to step down from a 6mm internal diameter to a 3mm diameter about 10mm from the tip (6mm ID for 170mm, then 3mm ID for the rest). I know this can be done, and we've specified a chamfer to make up the difference between the two IDs.
However, there is an interference issue and I'd like to propose a fillet instead of a chamfer - is this machinable? I'd think you can gun-drill or any other process to get your basic depth, then stick some kind of ball-end mill to get the radius - but can you do this at the bottom of an almost blind hole?
Thanks for your help.
RE: Deep hole drilling + ball-end fillet?
We routinely made a part very similar to your requirements using a profile cutter to transition from one bore to the other. Ours was in a flow application where we used a ball in the taper as a backflow preventer.
These people were nice to work with.
http://www.conicalendmills.com/default2.htm
Steve
